Scan To USB Issue
  • Copyguy69420
    • May 2024
    • 45
    Scan To USB Issue
    When i plug my flash drive into a Sharp mx-3571 it scans the files successfully but when i go to computer it does not show that the files are there. It only shows one of the files. Sharp tech support told to update the firmware.
  • Hart
    • Feb 2024
    • 408
    "It only shows one of the files."
    Which one ?
    Is the USB in FAT32 ?
    • Copyguy69420
      • May 2024
      • 45
      What format should the usb be in?
      • PacMusee
        • Aug 2016
        • 55
        First, have you checked your USB drive on another computer to verify it's not just this one with the issue? Is it PC or Mac?
        I've had similar issues myself, but only the other way around (files not appearing on the copier when trying to retrieve them, or unrecognised USB drive). It was either a matter of FAT32 vs NTFS formating or simply the copier was too ancient and could not show as much files as the drive contained on the menu, hence they "weren't there" even if they really were...
        • Copyguy69420
          • May 2024
          • 45
          I changed the usb file format and it still shows one file and not multiple files on the usb.
          • ihatefinishers13
            Senior MFP Technician
            • Feb 2020
            • 696
            what file type are you scanning over? how many scan files are supposed to be there? You're not scanning 5 pages at one time and expecting file different files, are you?
            • Copyguy69420
              • May 2024
              • 45
              The file type is PDF. So I scanned 3 different documents 1 after each other so there should be 3 different files. I am not expecting there to be 5 different files for a 5 page document.
              • Hart
                • Feb 2024
                • 408
                But do you have the 3 pages in the PDF ?
                If you expect 1 page per PDF, you need to change this settings :
                • Copyguy69420
                  • May 2024
                  • 45
                  Yes i do. Also i figured out the issue it was a file name issue they had it set to image. And everytime they scanned it would overwrite the file name.
                  • ihatefinishers13
                    • Feb 2020
                    • 696
                    Ahhh that makes sense. We always leave it on date/time stamp, otherwise the customer can change it each time with the pull out keyboard.
                    • Copyguy69420
                      • May 2024
                      • 45
                      yeah i didn't realize that until i checked her copier and googled it.
                      • Copyguy69420
                        • May 2024
                        • 45
                        I have another question about this the client wants it image 1 image 2 image 3 and so on but once i scan to a usb it deletes the first file any way i can change that settings??
                        • ihatefinishers13
                          • Feb 2020
                          • 696
                          Could you elaborate a little better on what they want? I'm assuming you mean they want "Image 1" as the file name, but haven't had it delete the files on USB..
                          • Copyguy69420
                            • May 2024
                            • 45
                            When the client had the file name as Image 1 the scan to the usb would over write the old file. So i changed it to date time. So now the client wants the file name to be Image. Is there a way around this.
                            • ihatefinishers13
                              • Feb 2020
                              • 696
                              You can set it for a specific word, but you would need to change something else about it, otherwise it will overwrite. You can also try the "unique identifier" check box here
