MX-FN27N connection harness.
  • Hansen88
    • 1055
    Hello, I have a FN27n on a 4071 that the connection cable got damaged when machine was moved. I cant seen to find a part number for the cable in the part book. Maybe I am blind. Does anyone know what the cable number might be? Thanks for any help.
  • Doug.P
    • Aug 2015
    • 44
    I think this is the right cable 0CW4M560590// BH GX N C CABLE_PRINTER_IF_S
    • Hansen88
      • 1055
      Not sure if that one is it. It shows more connectors on it than it is supposed to. One end has one connector and a ground wire, the other end that plugs into the machine has two connectors
      • Doug.P
        • Aug 2015
        • 44
        That's the only that shows that is the printer interface cable.
        • Doug.P
          • Aug 2015
          • 44
          Originally posted by hansen88
          not sure if that one is it. It shows more connectors on it than it is supposed to. One end has one connector and a ground wire, the other end that plugs into the machine has two connectors
          i also found this bulletin
          • Hansen88
            • 1055
            Thanks. I ordered that one and the only one that shows the correct amount of connectors on it. Hope one of these two works.
            • Hansen88
              • 1055
              You were right. The number is updated to 0cw4m56059002 I ordered and it came in as this number and id correct harness. Thanks a lot.
