Sharp 70M45 says network time out error when scanning large jobs of 10 to 50 pages
  • Copyguy69420
    • May 2024
    • 45
    when i scan on my sharp machine it gives the error message of network error time out error. It happens when scanning large jobs of 10 to 50 pages. It happens when scanning to both email and network folders. I have restarted the machine and taken out the ethernet cable many times same issue still occurs.
  • ihatefinishers13
    Senior MFP Technician
    • Feb 2020
    • 694
    This isn't the same customer as that 476W with a similar issue is it?
    If it's not, does it scan to USB okay? If it does, then it might not be the machine as it could be a network issue.
    • Copyguy69420
      • May 2024
      • 45
      It is a different issue. When this client scans large documents to email and folder it says network error time out error. I have updated the firmware and still does the same thing. I checked the file size for scan to email and it is set to maximum. What on their network could be blocking large scans of upto 70 pages reaching their email or their network folders? This machine is BP-70M45.
      • ridgemill
        • Sep 2017
        • 190
        Try a different network port, faulty ports on the hub/router/switch could be dropping the connection.
        If it happens with both SMB and email, you can rule out antivirus, but there may be a block on the firewall.
        • Copyguy69420
          • May 2024
          • 45
          Where would i check on the firewall? This machine was scanning to email and folders before.
          • ihatefinishers13
            • Feb 2020
            • 694
            My guess would be a connection issue. It could be temporarily dropping off here and there. Try using command prompt, use the ping command with -t at the end to continuously ping something else on the network.
            • Copyguy69420
              • May 2024
              • 45
              i did the ping command and it pings fine.
              • ihatefinishers13
                • Feb 2020
                • 694
                What about pinging WHILE scanning?
