U2-74
  • glimmer1980
    • Aug 2014
    • 105
    U2-74
    Hello,
    We have 2 printers now with an U2-74 error code. One MX-2651 and one MX-3071. The manual states to install the latest FW.
    A couple of weeks ago on the MX-2651 we installed the latest FW and since this morning the error code returned.
    Has anyone else had this problem?
    Regards,
    Ramon
  • mloudy
    • Oct 2015
    • 781
    Re: U2-74
    We had a MX-2651 that went into U2-74 three times in three weeks. The first call we upated the firmware. We ended up replacing the MFPC-SCAN pwb on 11/8/2021 and it hasn't came back.
    • copiertec
      • Jan 2016
      • 2201
      Re: U2-74
      Sharp really does not go into to much detail on this error (Data corruption due to storage error, data abnormality) just says to use 49-1 (Firmware) to resolve the issue. When does this happen, copies/scans or prints? Keep us posted on your results.
      • mloudy
        • Oct 2015
        • 781
        Re: U2-74
        In our case it was when faxing. There were several receiving issues leading up to the U2-74. Five in three months prior to replacing the pwb.
        • glimmer1980
          • Aug 2014
          • 105
          Re: U2-74
          @copiertec the strange thing is that the U2-74 came in the middle of the night. I don't believe that someone is working there around that time.
          • mloudy
            • Oct 2015
            • 781
            Re: U2-74
            I am working up a timeline using MICAS and email alerts for our U2-74. Many of them occured at 3AM or at least that is when MICAS logged them. I am certain the machine kept working with the U2-74 for days based on when the customer called in for service. This is a public library and had no use in the middle of the night except maybe a fax coming in. I could get a recent transmission log and see of they really do get an incoming fax at 3AM every day.
            • mloudy
              • Oct 2015
              • 781
              Re: U2-74
              The machine must have ran with the U2-74 in the background as the customer only placed 3 service calls for this error.
              Calls were placed on:
              10/19/2021 1:02PM
              10/21/2021 12:50PM
              11/8/2021 1:00PM
              MICAS Record E-mail Alert
              Monday 11/8/2021 12:46:56 PM 12:47 PM
              Wednesday 11/3/2021 3:00:08 AM NONE
              Tuesday 11/2/2021 9:53:24 AM 9:54 AM
              Tuesday 11/2/2021 3:00:08 AM NONE
              Monday 11/1/2021 12:49:26 PM 12:50 PM
              Monday 11/1/2021 12:46:56 PM 12:47 PM
              Saturday 10/30/2021 3:00:22 AM NONE
              Friday 10/29/2021 7:00:04 PM 7:01 PM
              Friday 10/29/2021 6:27:46 PM NONE
              Thursday 10/28/2021 4:35:48 PM 4:36 PM
              Thursday 10/21/2021 1:54:02 PM 1:55 PM
              Thursday 10/21/2021 3:00:22 AM 3:01 AM
              Tuesday 10/19/2021 3:38:20 PM NONE
              Tuesday 10/19/2021 3:00:06 AM 3:39 PM
              Monday 10/18/2021 4:04:44 PM 4:05 PM
              Sunday 10/17/2021 3:00:22 AM 3:01 AM
              Saturday 10/16/2021 3:00:22 AM NONE
              Friday 10/15/2021 4:51:26 PM 4:52 PM
              Tuesday 9/7/2021 1:06:38 PM 1:07 PM
              • JLSam
                • Jun 2015
                • 605
                Re: U2-74
                I'm curious, what firmware version did it have before the update?
                • mloudy
                  • Oct 2015
                  • 781
                  Re: U2-74
                  04.50.Z2.00 updated to 05.00.Z2.00
                  • glimmer1980
                    • Aug 2014
                    • 105
                    Re: U2-74
                    I allready updatet to FW to 5, but still the same message in the middle of the night....
                    • OlliK1969
                      • Nov 2016
                      • 310
                      Re: U2-74
                      Hi
                      Error U2-74 indicates a problem with firmware recovery and can be reset by the operator by acknowledging (OK) the error display.
                      On devices that are not switched off overnight, the device firmware is checked at 3:00 a.m. If a change in the firmware is detected during this check, the original firmware is restored. This is a security function that prevents manipulation of the device firmware. This function can be activated/deactivated in the security settings of the device.
                      Technical report Sharp Germany
                      • glimmer1980
                        • Aug 2014
                        • 105
                        Re: U2-74
                        @OlliK1969 Where would i find this security option on the machine?
                        • mloudy
                          • Oct 2015
                          • 781
                          Re: U2-74
                          Log in as Administrator.
                          Systems Settings
                          Security Settings
                          Conditions Settings
                          √ If Firmware Corruption is Detected, Restore It
                          • RColon-Fraser
                            • Jan 2021
                            • 5
                            Re: U2-74
                            I have also experience this issue. I tried a firmware update and then tried the CN Update. Sharp recommended the eMMC/mSATA card, which I replaced, but the problem wasn't resolved until I replaced the MFPC unit.
                            • boutn
                              • Jun 2016
                              • 547
                              Re: U2-74
                              Originally posted by OlliK1969
                              Hi
                              Any idea where you can deactivate this setting?
                              Or do you have that Technical Report? Because there is no such report in BeNeLux
                              Because changing the motherboard on a crapload of machines that are throwing this error doesnt seem like an option.
