Sharp MX-M365 Printing Blank
  • LlessurElad
    • Apr 2024
    • 11
    Any ideas on what would cause these printers to print blank? The only thing I did was to pull the process unit out. The drum & the maintenance kit have only gone about 12% of their estimated yield.
  • copiertec
    • Jan 2016
    • 2206
    What was the reason you pulled out the process unit out? Did you have blank prints/copies prior to this issue? Was the mfp off when you removed the unit? Is everything seated properly and plugged in tightly?
    • LlessurElad
      • Apr 2024
      • 11
      It was printing fine before I pulled it out. The machine was off & everything is seated properly & plugged in tightly.
      • ihatefinishers13
        Senior MFP Technician
        • Feb 2020
        • 695
        Did you remember to plug the discharge lamp back in? Also, are they COMPLETELY blank? Or super light?
        • LlessurElad
          • Apr 2024
          • 11
          Discharge lamp is plugged back in. Prints are COMPLETELY blank.
          • Hansen88
            • 1066
            I dont see what would have went wrong, but have you checked if the developer unit and the drum are turning?
