Setting machine back to default values in sims.
  • Hansen88
    • 1053
    Hello, I am on a MX-3071. It is a used machine we picked up. I want to set everything back to defaults. I tried initialize private data-data in machine. I tried changing to different country and back to US. I changed some values in the sims and they did not change when I tried these two things. I am pretty sure there is a way to reset fully, I just cany find it. If anyone has any info I would appreciate it. Thanks.
  • havokprod
    • Oct 2012
    • 159
    My routine when we purchase used equipment from the wholesaler is,
    1 Figure out if the admin password is set to "admin" if not follow this thread
    2. initialize private data
    3. Sim 66-10 Used to clear the FAX and image send
    image data. (The confidential data are also
    cleared.)
    4. Sim 67-17 Printer controller reset/Default value setting
    5 Web portal, "system settings"-"storing / calling of system settings"- "restore factory defaults"
    6. Firmware update.
    any one else what to chime in?
    • HikingAK
      • Sep 2017
      • 13
      The same except reformat HDD using sim 62-1 as well.
      • ihatefinishers13
        Senior MFP Technician
        • Feb 2020
        • 665
        cleared.)
        6. Firmware update.
        Once you do initialize private data, pretty sure you don't need to do anything in the web portal for factory defaults, as it does that. I can't say for certain that it does anything for simulations though. I would assume it would, however.
