MX-3071/5071 fuser bearings
  • sharpie
    • Feb 2011
    • 182
    Does anyone know what the bearing part number is for the fuser belt unit heat roller? There is no parts breakdown in the parts manual for the belt unit and it seems a little crazy to pay $253.00 for a unit to fix a noisy bearing. I am trying to locate a bearing on another model that fits but the heat sleeve on the ends of the roller make it an odd size.
  • ihatefinishers13
    Senior MFP Technician
    • Feb 2020
    • 709
    If the age of the belt unit is more than 3 years, I would just replace the belt unit anyway, the holder for the top rod is going to be broken soon any minute now anyway.
    • sharpie
      • Feb 2011
      • 182
      I have never had one break and have been rebuilding these fusers for years now.
      • iHateSharpFusers
        • Jul 2024
        • 38
        Really? What failures have you seen most? Putting any parts into the belt unit, besides replacing the whole thing, is like trying to polish a turd.
        • ihatefinishers13
          • Feb 2020
          • 709
          You haven't had the rod holders break for the fusing belt unit? I don't believe you. The highlighted part breaks for us all the time, causing the fuser to lock up and throw an L4-03.
          • Hart
            • Feb 2024
            • 411
            "The highlighted part breaks for us all the time"
            I've had this problem, but it's extremely rare.
            • ihatefinishers13
              • Feb 2020
              • 709
              Dang, over the last 9 years of the Phoenix/Phoenix2 machines, I'd say that's about 20% of the reason we have to replace those belts.
              • boutn
                • Jun 2016
                • 547
                I second that...the fusers lock up all the time because of this.
                What are we doing wrong?
                • ihatefinishers13
                  • Feb 2020
                  • 709
                  Trusting that Sharp will make a fuser that lasts to it's maintenance interval ever again...
                  • lky1978
                    • Mar 2009
                    • 483
                    NBRGP1065FCZZ BUSHING
                    • sharpie
                      • Feb 2011
                      • 182
                      It is a correct and true statement that we have never had a break failure on the rod holders. Most of my machines run fuser temp at -5. I can rebuild a fuser for $85.00 plus thermistor in about 40 minutes, I just need bearings now, the bushings are available I know.
