BP-70C65 pulling magenta non stop
  • Hart
    • Feb 2024
    • 415
    Customer complain that every copy and prints are pink, and yes they are
    I've changed :
    Drum unit and DV (not DV unit)
    Process control sensors
    1st and 2nd Transfer unit
    LSU and LSU FFC (the ribbon)
    Clean and reapply conductive grease
    Clean all contact and check for pollution on all PWB
    22-06 and an example of a Cyan only copy below
  • Doug.P
    • Aug 2015
    • 55
    I would suggest you replace the whole DV Unit and new DV.
    • ihatefinishers13
      Senior MFP Technician
      • Feb 2020
      • 709
      I've changed :
      MY GUY, we had this problem with Yellow. MC PWB. CHECK IT. A part on it actually cracked on ours, it was in the field for maybe a year before it happened.
      • iHateSharpFusers
        • Jul 2024
        • 38
        I second this
        • pbbsinc
          • Nov 2005
          • 92
          I see you posted you swap the Drum assy but if you did not try this and also check the charge connections behind the drum assy. It is a write to black system meaning no charge black copies weak charge background copies.
          I have seen this with two of my machines those copiers have charge roller technology and if the process drum unit is defective or charge roller is defective it will cause pink outcome because it is not getting its charge. Easy trouble shoot is to swap the magenta drum assy for the yellow and see if copy quality follows the unit. If it does follow change the drum assy with a good one.
          • Hart
            • Feb 2024
            • 415
            IT WAS THE MC PWB
            THX
            • Hart
              • Feb 2024
              • 415
              Yeah ... Got a brainfart at the time. After replacing the Drum unit my Sharp rep asked me "Why did you not swap it with Black to see if it follows ?"
