Have this unit, 2 years old with 361K images. It will randomly throw a POD1_N or NA jam anywhere from 2 to 1000 images. Client uses exclusively trays 1 and 2. Can't seem to duplicate this when I am there. I've run hundreds upon hundreds of copies without a problem.
All firmware and maintenance are current (actually not even to it's first PM point yet)
fuser has been rebuilt recently
all rollers in the LCT are new
removed the fuser drive unit to check for binding
everything seems to be in working order
replaced the POD1 sensor (unit worked for 10 days without a jam and now has started up again)
unit is on a dedicated 20A line
As a side note I recently replaced the fuser drive motor for L4-03 problems but the jamming per-existed the L4 problem (although they may be related)
Previous generation had a clutch problem in the LCT drive but that would normally cause TRAY1_L or TRAY2_L, I am wondering if this might be something similar? This is at a school and the contact is pretty good at checking paper in trays and all of the other operator caused issues so I'm not thinking damaged paper. They use the same brand in 11 schools and this is the only one having issues.
Any an all suggestions would be greatly appreciated. I am headed back there in the morning to observe and see if I can find any clues.
Thank you for your time and effort in this matter
Bil
Bil
