MX-M363 5 dot pattern
  • GThomas222
    • Jun 2025
    • 3
    I'm getting a 5 dot diagonal pattern going down the page on copies and internal prints such as the config page or meter report. But when I print test prints or lists in service modes the dot pattern isn't there. Any suggestions would be appreciated. Thanks.
  • ihatefinishers13
    Senior MFP Technician
    • Feb 2020
    • 695
    Samples? Any troubleshooting measures taken?
    • GThomas222
      • Jun 2025
      • 3
      DOC060325-06032025160204.pdf DOC060325-06032025160218.pdf
      Here is a config page with the dots and a settings page from service mode without the dots. It obviously has to be an electronic or software issue since prints from service mode have no dots but other than that I have no idea
      • Hart
        • Feb 2024
        • 403
        Security : MX-FR23U
        You have the DSK installed, I would check in the settings for a watermark
        • mloudy
          • Oct 2015
          • 784
          The error codes on the 22-6 point to pwb problems. As the copier is over 13 years old I would tell the customer there is a pwb issue and they are no longer available. The MX-M363N was officially placed on the End of Life list by Sharp on 1/29/2021.
          The End of Life document from Sharp is a good resource to give to end users who have very old equipment and expect you to keep it running.
          • ihatefinishers13
            • Feb 2020
            • 695
            Originally posted by Hart
            Security : MX-FR23U
            Agreed, also the "Hidden Pattern" settings in Security
            • GThomas222
              • Jun 2025
              • 3
              Thanks for all your help. It was a security kit setting that needed to be turned of. You guys bailed me out. thanks again
              • Hart
                • Feb 2024
                • 403
                Do you have this document ?
                I have an Excel provided by Sharp France but I legally can't share it with customers (or anyone actually ...).
                • ihatefinishers13
                  • Feb 2020
                  • 695
                  It's all America models, but should give you a good idea...
