SharpMX-M365 E7-11 code
  • TSS
    • Jul 2018
    • 32
    Hi everyone.This Sharp MX-M 365 throwing E7-11 code.I cleaned optics,mirrors home position sensor.Code went away and came back the next day.I then resitted all the ribbon cables to lamp and scanner controller.No luck.Then I took out laser and cleaned it up.very dirty.Code still here.I noticed in warmup the scan lamp comes on when it goes back to home it codes out.Not sure what's causing this issue.Any suggestions are appreciated. Thank you.
  • Doug.P
    • Aug 2015
    • 55
    Check the white reference plate on the under side of the glass is either dirty or damaged.
    • ihatefinishers13
      Senior MFP Technician
      • Feb 2020
      • 709
      Always check bulletins. https://service.sharpamericas.com/id...FP-TB-1110.PDF
