Sharp mx m2651
  • davebtech
    • Apr 2015
    • 176
    Sharp mx m2651
    Trying to get into settings from op panel and it says please wait forever after pressing settings, tried going onto webpage that works , but when I put in admin password it says wrong password. Also cust is complaining about dropped printing jobs……….. had cust over 20 years he didn’t change it. Any one see this stuff? Thanks Dave
  • ihatefinishers13
    Senior MFP Technician
    • Feb 2020
    • 715
    There's a good chance that the HDD is failing. On the 22-6, 5th page, towards the bottom, look for HDD smart info. It should be all zero's, if it isn't, there's an HDD problem. Any errors, or PRI jams on the 23-2?
    • davebtech
      • Apr 2015
      • 176
      Can I swap another hard drive from another 2651 ? Thanks Dave
      • ihatefinishers13
        • Feb 2020
        • 715
        If it's working, sure. I would just try to backup the machine in simulation first, and push it on afterwards. Most stuff should stay, but authentication doesn't usually come back.
        • davebtech
          • Apr 2015
          • 176
          Awesome thank you! Lucked out over the years with having to replace one, will a Toshiba 500 gb 2 1/2 blank one new format itself?
          • mloudy
            • Oct 2015
            • 790
            That HDD will work. We used the Toshiba MQ01ABF050 but now we install SSD drives.
            • davebtech
              • Apr 2015
              • 176
              Great thanks does it get formatting automatically …….?
              • Hart
                • Feb 2024
                • 421
                If it's a new one (without any format), yes, if not you need to format it in 62-1
                • davebtech
                  • Apr 2015
                  • 176
                  Great thanks Dave
