Waste toner alerts
  • Charli3
    • Jun 2025
    • 3
    Waste toner alerts
    We have started using printanista. It seems to report well on the toners, with a 25% alert.
    On the waste toner we only seem to be getting 100% then 0%
    Does anyone know how to configure an alert on it.
  • ihatefinishers13
    Senior MFP Technician
    • Feb 2020
    • 709
    There's nothing you can do. Sharp's don't even give a percentage on the machine itself. We send one out on the machine when installed, and put a label on the box, as well as telling multiple people there to CALL us when they use the waste box so they can get another one for the shelf since we can't track it.
    • mloudy
      • Oct 2015
      • 789
      I would see if there people in support at printanista that will work with you. When we started using PrintTracker we had this same issue with the waste toner containers and Sharps. It was either 100% or 0% Their response was that they could get any alerts to report showed up on the copier display. If you make sure every copeir has an extra waste container at install and you send one when your are alerted it hits 0% you will be good.
      I just looked at one of our PT installs.
      On 5/14/2025 a MX-3050V indicated an alert for "The waste is low".
      On 6/4/2025 PT sent an email with the subject line "MX-3050V Waste at 0%". In the body it shows Alert: Replacement, A waste was replaced at (Customer name). It also gives the SN and location. So there was an alert for "waste low" 3 weeks prior to it needing replaced.
      This copier also sent an email through the Alerts Setting.
      5/14/2025 email
      Date/time
      Device Name
      Model
      SN
      Tag#
      "Device has detected: !!!!!Replacement the waste toner box required soon. !!!!!
      • Hart
        • Feb 2024
        • 415
        Kpax is reporting 5% when the copier is telling "Waste almost full prepare one" (at least on the CR4.5 and CR5).
        We send a new one when we have the message "Waste toner full" to replace the one they're supposed to have.
        • boutn
          • Jun 2016
          • 547
          We are also using Printanista, but the 'waste toner almost full' alert can not get captured it seems.
          I already asked a few times...
          We use the machine email alerts for the waste toners.
          If you ever get this to work, let me know!
