Sharp MX-M365N need firmware
  • WilliamUS
    • May 2022
    • 1
    Hi, friends!
    I'm very need a firmware Sharp MX-M365N file .sfu.
    Thank you very mach!
    William
    spgspg000@gmail.com
  • Jhonjon
    • Sep 2013
    • 208
    Re: Sharp MX-M365N need firmware
    Originally posted by WilliamUS
    Hi, friends!
    William
    spgspg000@gmail.com
    Standard firmware share to your e-mail.
    • Haileab
      • Jun 2022
      • 2
      Haileab.nesebho@gmail.com
      • Haileab
        • Jun 2022
        • 2
        I need the firmware to your help is apreciated...
        • tim-tum88
          • Apr 2024
          • 7
          Hello,
          If possible can i get a copy of this firmware. The version have i have (ver02.10.o1) does not support TLS ver 1.2 and as a result i am unable to scan to email with Office 365.
          thanks in advance
          • ihatefinishers13
            Senior MFP Technician
            • Feb 2020
            • 709
            Originally posted by tim-tum88
            Hello,
            thanks in advance
            302 Moved
            • tim-tum88
              • Apr 2024
              • 7
              Thank you, just to clarify though, there are 3 files. Is there a particular order i should install them in, or should i just do the TLS upgrade,
              thank you again
              • ihatefinishers13
                • Feb 2020
                • 709
                thank you again
                Just do the TLS file, it should do the trick. Also, you may need to mess with the settings in Security > SSL Settings
                • tim-tum88
                  • Apr 2024
                  • 7
                  Hello,
                  i placed it on a flash and tried to update but the message on the MFP is saying to enter a flash with the firmware.
                  the flash is formatted in fat32 and the file is in the root of the flash with nothing else on it. What could be the issue?
                  I also tried another flash.
                  • ZOOTECH
                    Senior member of CRS
                    • 3375
                    Hello,
                    Did you try the other USB port?
                    • tim-tum88
                      • Apr 2024
                      • 7
                      Yes i've been trying to update from the USB port on the MFP
                      • ihatefinishers13
                        • Feb 2020
                        • 709
                        Just curious, you're going into 49-1 and updating, correct?
                        • tim-tum88
                          • Apr 2024
                          • 7
                          Yes that is correct
                          • ihatefinishers13
                            • Feb 2020
                            • 709
                            What size flash drive? Gotta be less than 32GB more than likely. You can also go to the service webpage(not the normal webpage), by going to https://IPADDRESS/service_login.html with the password of service. And update it that way.
                            • tim-tum88
                              • Apr 2024
                              • 7
                              Is there a default password for that service area? I'm not sure what it is. thanks
