Sharp MX-M753 replaced DSPF control board
  • dustzona
    • Mar 2015
    • 83
    I replaced a bad DSPF control on a MX-M753 with a board from another machine . It keeps giving a E6-11 code, if I'm remebering correctly. I probably need a shading adjustment sheet , part # UKOG-0333FCZZ . I dont have a source for that sheet ,so if someone has one to sell has a source for it that would help . thanks , also looking for a used control board CPWBX1846DS51 , 52 ,60
  • mloudy
    • Oct 2015
    • 788
    Re: Sharp MX-M753 replaced DSPF control board
    I have a MX-M623N in the disposal area so I pulled the ADF board from it. It has 1846DS62 stamped on it. If you want it you can have it for the cost of shipping.
    We should also have a UKOG-0333FCZZ floating around that we will likely never use again.
    • JR2ALTA
      • Feb 2010
      • 2033
      If you have a little patience they are not hard to make on your own. Cut a white sheet, roughly like this.
      • dustzona
        • Mar 2015
        • 83
        My email ( affix60@gmail.com ) send me an invoice . Thank you !
        • dustzona
          • Mar 2015
          • 83
          Thanks , I'll try that
