Sharp ARM-205 L6 code
  • dcycle
    • Sep 2006
    • 37
    I know it is in the polygon motor area. I want to know if anyone else has had this code and what was the fix.
    Thank you for your help!!!
    David
    Only two defining forces have ever offered to die for you:
    1. Jesus Christ
    2. The American G. I.
    One died for your soul, the other for your freedom.
  • ZOOTECH
    Senior member of CRS
    • 3375
    New p/n for just the polygon motor is RMOTN0022QSPZ. It is a lot less expensive to replaced just the motor, but it is a gamble that the motor was not causing the error.
      • 23007
      No mystery here. Replace the laser assembly. =^..^=
      • dcycle
        • Sep 2006
        • 37
        ZOOTECH - Thank you for your information. I thought it would be the motor but wanted other ideas.
        David
        1. Jesus Christ
        • dcycle
          • Sep 2006
          • 37
          blackcat4866 - Thank you for your input!!
          David
          1. Jesus Christ
          • vlad_robas
            • Oct 2006
            • 225
            never heard of someoane to fix this kind motor, u can only delay it in some cases, i heard of it hapend at Minolta too, and Ricoh/Lanier 5218 have same motor like Sharp ar5316 i've tryied that
            at this series at about 300k poligonal motor is droping
            • dcycle
              • Sep 2006
              • 37
              FIX - Replaced the Laser Assembly.
              Thanks to everyone for their input.
              David
              1. Jesus Christ
