Sharp ar-m455 cis trouble
  • J_Lee
    • 111
    I have a problem with the shading trouble on the 2nd side of the duplexed copy (top). I have already tried swapping out units from parts machines and it works for a little while but then returns. I performed a shading calibration and it went away for a while also but returned. I also did a copy quality adjustment and again same result. The copies are coming out dark within the frame area. I am hesitant about buying a new unit as I have already tried about 3 other parts machine units I wouldnt think they could all be bad... Maybe I installed incorrectly. Any help would be appreciated.
    • 23006
    Check out this post:
    http://www.copytechnet.com/forums/sh...djustment.html
    • J_Lee
      • 111
      Ended up being the height adjustment on the left side of the document feeder!
        • 23006
        Congratulations! Thanks for popping back to let us know. =^..^=
