Problems with a sharp AR 5316 With strips
  • Harry
    • 228
    Worked on 5316 last day with clear band 2 3 times on an A4 copy changed Drum and it simes like good after a view days same thing does anybody know wath it is?checked also for broken tears and gears nothing found ad else please help Thanks alot
    • 22996
    You might take a look at the developing drive. Gears ground down or spun on a "D" shaft, or maybe a seizing developing cylinder. =^..^=
    • Harry
      • 228
      Sharp 5316
      The Circoferenze is from Drum and i changed it and it works fine four a couple days.My question can it be a thermical problem? Fans not Work It looks like the Developerbrush alterate the surface of the drum.
      Thank you for respons!
      • semaj
        PhilTech
        • Mar 2009
        • 28
        fix the cleaning blade of your Drum bro..or the opc drum may have a scratches along its side (white )..put remedy on it.
        • Harry
          • 228
          sharp 5316
          There is no scratch on the Drum and the cleaning blade works fine also
          Please find other solutions Thanks at all
          • petrus
            • 155
            try change the transfer charger.it could be sometime.
            are you sure there are no spoilt of all the drive gear at the back?
            better double check it....
