MX3070 fusing belt versions
  • Toner Boy
    • Aug 2007
    • 366
    I know the MX607FB is the OG one. I've used MX608's and seem to have no issues, but not tested a lot (designed for MX6070)
    The MX601FB looks nearly identical but mates w/MX601LH...thermistors different ?
    Anyone tested 608's/601's in these units successfully? and what press roller...607/601
  • bilyahn
    • Dec 2006
    • 1470
    Re: MX3070 fusing belt versions
    I use the 608FB with the 607LH for this series at all speeds they have worked well for us. Only have 10 or so of these but after the initial nightmare yields are definitely up for us with this combo. Have to keep an eye on the belt and run the fuser cleaning at each service call.
    Good luck
    Bil
    • Toner Boy
      • Aug 2007
      • 366
      [QUOTE=bilyahn;2248057]I use the 608FB with the 607LH for this series at all speeds they have worked well for us. Only have 10 or so of these but after the initial nightmare yields are definitely up for us with this combo. Have to keep an eye on the belt and run the fuser cleaning at each service call.
      Thanks for input. Have been removing the metal gear and 2-step gear that mates with it, removed from production per bulletin; might be keeping the belt from sucking the cleaning roller for a while longer.
      • bilyahn
        • Dec 2006
        • 1470
        Yes we did this also!
