Can you convert a MX5050 Fuser to a 3050 Fuser
  • Doug James
    • Jan 2012
    • 935
    [Misc] Can you convert a MX5050 Fuser to a 3050 Fuser
    Can you convert a MX5050 Fuser to a MX3050 Fuser ? They look exactly the same except for the Male bar in the back and the connector... Thanks so much for any comments !!
  • bilyahn
    • Dec 2006
    • 1470
    Re: Can you convert a MX5050 Fuser to a 3050 Fuser
    I would say no. The lamps are different. However if you had a 3050 fuser you could transfer all of the parts from the 5050 fuser and it would work just fine.
    Good luck
    Bil
    • Doug James
      • Jan 2012
      • 935
      Well I Jumped into it and it looks like the wire harnesses have different connectors. Wired slightly different also Well it was worth a shot...
