sharp ar157e loud noise
  • bruce 49dcs
    • Jan 2017
    • 140
    I sold this machine to him years ago and I havent worked on them for ever but ive had this problem before but cant remember what it was there is a very loud snap and clatter during start up comming from the rear right corner at the bottom I removed the dv unit drum unit toner and fuser all rotate with no issue I hope someone has had this and remembers thank you bruce 49 dollar copier service
  • ZOOTECH
    Senior member of CRS
    • 3375
    Re: sharp ar157e loud noise
    Check the spring clutch for the bypass tray, it might be dry and/or dirty.
    • ntbann
      • Jan 2012
      • 626
      I believe the reg clutch pawl is slipping.
        • 22996
        Also common on the Jaguar1 series, the fuser mounting screws can strip out in the plastic frame. So the sound you're hearing may be the fuser drive gears skipping off of each other. If yes, it's not a simple repair to replace the upper frame ... a lot like building a copier from scratch x2 (take everything off of the frame, then put everything back onto the new frame). =^..^=
        • subaro
          • Oct 2010
          • 1274
          Xerox made an identical machine that I use to work on about 20yrs ago, the XD150 I believe it was. They had a number of issues. Like the OP, can't recall many of the things, but I recall the fuser Gear use to crack and make noise, but still work. The Solenoid behind the machine, I think, the paper feed pawl release was the most common issue, it use to stick. Anyway remove the fuser and examine the fuser heat roller drive gear carefully.
