Sharp M205 L6 Sub10
  • mthomp
    • Jun 2025
    Sharp M205 L6 Sub10
    changed LSU and Main board from good M205 still get code shortly after power on
    help needed
    • 22993
    Did you replace the mirror motor only, or the laser assembly? In either case I have gotten a few new inoperative Sharp laser units.
    Also try replacing the ribbon cable. =^..^=
    • mthomp
      M205 L6 sub10
      customer LSU works in our test M205 copier
      same with main board
      why the ribbon cable?
      thanks for the reply
        • 22993
        It is very easy to damage the foil thin connections at the ends of the ribbon cable. All it takes is a razor thin crack in one of the conductors. =^..^=
