User Number Authentication problem
  • Abbe
    • Mar 2023
    • 3
    [Misc] User Number Authentication problem
    I got a new Sharp copier (BP70C45) that i need to install. The customer want the display to use user authentication by User Number but want the computer to NOT use user number when printing. Is this possible? Been trying for sometime now but only got the machine to wake up and print nothing.
  • CroceL
    Sharp / Brother Tech
    • Jun 2020
    • 60
    Re: User Number Authentication problem
    Create user that has everything allowed, save the number in the driver so the customer doesn't notice or has to input the code everytime. (Every PC same code)
    And for the machine create users as usual
    • bilyahn
      • Dec 2006
      • 1470
      When you setup authentication there is a check box for prohibiting print jobs from unauthorized user. Uncheck that and you should be good to go.
      Good luck
      Bil
      • Abbe
        • Mar 2023
        • 3
        The problem is that its on a school with many people that come and go with their computers. I need to find a way around using the code while printing or another way to look down the copy machines display for unauthorized personnel.
        • Abbe
          • Mar 2023
          • 3
          Good luck
          Bil
          I tried that but the job still wont come out, the machine just gives a small buzz and nothing more.
          • boutn
            • Jun 2016
            • 540
            Try printing in Black and White.
            Could be you made a user that only has permission for that.
            If you print anonymous, then the lowest persissions count.
            • skyfong
              • Aug 2012
              • 18
              First setting the drive, go to printer preferences, select job handling, you will find the auto job control review, tick it. Next time when print will pop out a window request you to keep the user name password or user number.
              • ihatefinishers13
                Senior MFP Technician
                • Feb 2020
                • 664
                There's also the option for the driver to ask for authentication (auto job review control) especially if they need to change their User Number when printing.
