sharp mx-607fb and a sharp mx609fb
  • clark
    • Sep 2016
    • 109
    I dont know but can you use a sharp mx-609fb in a sharp mx607fb. I got a lot of bad fuser here. Thanks
  • chatkal
    • Aug 2015
    • 47
    Re: sharp mx-607fb and a sharp mx609fb
    Different kits. MX-609FB for BW copiers. MX-607FB for Color
    • MHeon71
      • Oct 2008
      • 489
      Why are the fusers bad? Is it the B/W fusers that are going bad? If you rebuild the B/W fusers, do you run the belt meandering sim in TC - 6
      • ihatefinishers13
        Senior MFP Technician
        • Feb 2020
        • 700
        Unfortunately they are from two totally different fusing units. Are you also having a ton of issues with the MX 3050-6070/2651-6071 fusers? Our company ends up having to replace fusing belts and rollers well before their typical counter is up. I don't mind rebuilding them as they're easier than the 5141/3640 series' but they can't handle the amount of toner that is laid down; way too much buildup from dried toner on the separation plate and pressure roller.
        • CroceL
          Sharp / Brother Tech
          • Jun 2020
          • 62
          Update to newest firmware
          SIM 55-1
          SW32
          Bit 6 from 0 to 1
          This setting prints out a fuser cleaning page every 5000 prints.
          Since I've enabled this on multipe machines we have way less problems with toner clogged fusers
          • Sask1967
            Senior technician
            • Jun 2023
            • 7
            SIM 55-1
            SW32
            Bit 6 from 0 to 1
            When was the last time you started using the SIM since you have less problems with toner clogged?
            • JLSam
              • Jun 2015
              • 605
              I don't think he's been using it for too long. The first time I heard about this SIM was on MAY of this year, two months ago. When reading the bulletins on firmware updates. Before this, I've never heard of this Sim.
              From CCE-2917 May 8th, 2023:
              [For the purpose to reduce the jam due to the paper winding around the fuser,
              Fusing cleaning mode auto execution frequency setting has been added to Soft SW. SIM55-1 SW32 Data5-7
              (Fusing cleaning mode auto execution frequency)
              567
              000: Not execute (Default)
              001: Every 1k
              010: Every 5k
              011: Every 10k
              100: Every 25k
              101: Every 50k
              *At the time of auto execution, one paper is output in the same way as manual execution (System Settings > Image Quality Adjustment > Collective Adjustment > Fusing Cleaning Mode). ]
              • Sask1967
                Senior technician
                • Jun 2023
                • 7
                567
                001: Every 1k
                010: Every 5k
                011: Every 10k
                100: Every 25k
                101: Every 50k
                that helps. Many thanks!!!
