Sharp Rotate Sort
+ More Options
Posts
  • skyfong
    • Aug 2012
    • 18
    Sharp Rotate Sort
    Hi everyone, may i know Sharp Photocopier Machine able to setting 90 Degree rotate sort like Ricoh? Tray 1 paper A4 Portrait & Tray 2 A4R Landscape, when print, machine will pull paper from tray 1 after complete 1 set will pull paper from tray 2, so the output will be 1st set portrait & 2nd set landscape and continues it
  • boutn
    • Jun 2016
    • 540
    Re: Sharp Rotate Sort
    I know a Tiger does that
    But i doubt if you'd be able to buy one...
    • skyfong
      • Aug 2012
      • 18
      Sorry i cant get what your means?
      • boutn
        • Jun 2016
        • 540
        The Tiger series havent been in production for about 10 years or so, so i don't think you'll be able to buy one.
          • 22989
          Did you have a specific model number in mind?
          Most MFP's with two trays and without a finishing option come with the rotate sort option. Often when the finishing option is installed, the rotate sort function is no longer accessible.
          It will come down to which model, and what combination of accessories. =^..^=
          • skyfong
            • Aug 2012
            • 18
            For Model like MX-M4070, yes i know for the Sharp Photocopier are come with function sorting, but i would like to setting it to 1st set portrait & 2nd set will be landscape sort, i try simulation check but unable to found the function
              • 22989
              Did you say whether your machine has a MX-FN27N, MX-FN28, MX-FN29, MX-FN30, or MXFN31 finisher? Do you have two paper trays, set to Letter & Letter-R respectively?
              The brochure lists "electronic sorting", but there are no details in the brochure or the operators guide regarding electronic sort or rotate sort.
              Specifically on Kyocera, the rotate sort functionality disappears when any finisher is installed. Maybe the same on Sharp?
              Perhaps it needs to be enabled as an option or in the DIPSW? =^..^=
              • ihatefinishers13
                Senior MFP Technician
                • Feb 2020
                • 656
                Sharp doesn't have this option for some reason. None of the usual machines have it, not even the BP models. I'm not sure about the 7090/8090 series or ones with certain finishers, but the typical models do not support it.
                • Imprestik
                  • Aug 2012
                  • 296
                  All Sharp copiers collate no matter what option is installed.
                  I know on the Ricoh's the collate option is an extra which needs to be purchased unless a finisher is purchased with the configuration.
                  This is a poor mans way on the collate option but I do not think you can do it on a sharp device.
                  I suggest you just select collate as standard when printing and copying so it separates the jobs as you wish
