MX 3114N Blinking Green light won't turn on
  • gtiporter40
    • May 2023
    • 16
    [Dead] MX 3114N Blinking Green light won't turn on
    Hello.
    I have an MX3114n for occasional home use.
    I noticed that the machine seemed to be doing stuff at idle a week or so ago. It wasn't just quiet. I think it was making noises or clicking or flickering -something like that. I just switched it off. I tried to start the machine a few days ago and just get a blinking green light.
    I have taken out the SD card and can't read it on the computer -it just says "please insert a disk" and it does this a on a different reader as well
    I think it may be corrupt therefore. I can't see anywhere to buy this. Can anyone provide me with the firmware for me to try this on a different card. I am happy to pay some money for this and I think it may be the place to start before checking anything else unless anyone tells me differently
    Chris
  • leo34staffs
    copierman
    • Aug 2007
    • 503
    Re: MX 3114N Blinking Green light won't turn on
    Originally posted by gtiporter40
    Hello.
    Chris
    Download a free copy of hdd raw and see if that will see the sd card, from there, if the card is OK you can clone it to a new sd card, although firmware may need to be installed after.
    Networking skills are advantageous but use of a 3m vacuum cleaner is essential
    • gtiporter40
      • May 2023
      • 16
      Thanks for that. Hd raw saw the card and I cloned it to another sd card with success. I tried that in the machine and powered it back on and it still just blinks green.
      Maybe the power board then? If so, do I have to get this from sharp or has anyone a spare they might sell?
      • Elmo
        • Feb 2010
        • 541
        Firmware may be worth a try before you order a board
        on the board just to the left of the sd card are 2 switches
        1 is to boot from the sd card the other for Firmware update switch this to on and see if the screen loads to update
        I Used To Live To Fix Things Now i Fix Things To Live
        • gtiporter40
          • May 2023
          • 16
          I will try this first. Thank you.
          • copiertec
            • Jan 2016
            • 2211
            Hdd also causes issues, for the life of me I don't know why Sharp uses Toshiba hard drives, they suck.
            • gtiporter40
              • May 2023
              • 16
              I'll try this as well before looking at power. I'm assuming there is nothing on the hard drive and to just swap it out and see if that does anything. Thank you
              • copiertec
                • Jan 2016
                • 2211
                Firmware is stored on the HDD.
                • gtiporter40
                  • May 2023
                  • 16
                  Firmware on the sd card and hdd? How do I check the firmware on the hdd and how do I replace that. Do I order a hdd with firmware on it from sharp?
                  • driving lots of miles
                    • Jun 2016
                    • 399
                    Maybe I am missing something here but if the SD card was bad and you cloned that card, you would still have a "new" bad SD card?
                    • copiertec
                      • Jan 2016
                      • 2211
                      Yes, part of it, the e- manual and watermark firmware is stored on the HDD, the ICU/ boot firmware is located of the SD card. If you were to install a new HDD in the machine it will format automatically but you will receive e manual/ watermark error codes.
                      • copiertec
                        • Jan 2016
                        • 2211
                        I agree with driving lot of miles, if you have a faulty sd card and clone it to another new sd card, the cloned sd card could be faulty as well.
                        • mloudy
                          • Oct 2015
                          • 790
                          I would start with a known good SD card image and copy it to a new SD card.
                          • gtiporter40
                            • May 2023
                            • 16
                            OK. So I will start with a good known card and try that and then maybe look at the hdd. Do I need to go to sharp for this?
                            • boutn
                              • Jun 2016
                              • 547
                              any sdcard of the same or bigger size will do.
                              You just need another card that works to copy it with HDD RAW COPY
                              Or you need an image of a working card.
