MX 3114N Blinking Green light won't turn on
  • gtiporter40
    • May 2023
    • 16
    Re: MX 3114N Blinking Green light won't turn on
    I have a new sd card of the same size. I have the original sd card from the machine that may or may not be corrupt so I need known good firmware to put on the new card. Will sharp sell me this or can anyone here provide that which I am happy to pay for. I am assuming sharp either won't sell it to me or may do so at a higher price than on here.
    • mloudy
      • Oct 2015
      • 782
      I have lots of images but not for a MX-3114N. I am not sure if it a US model or not. I would say the file you copied off of the old SD card is corrupt and can't be used to copy to a new SD card.
      Two options. Buy a new MX-3114N from Sharp. This will come loaded with the correct files on it. Option two is to find someone with a image from a good MX-3114N SD card OR someone willing to pull one from a working MX-3114N and copy it.
      • gtiporter40
        • May 2023
        • 16
        Thanks. I'm not back home til Friday. I will enquire with sharp then unless anyone else can help with the image beforehand. Im in the uk so i assume its a uk or europe model. I'm hoping it is just the card. The machine is great otherwise. Good for occasional scans and the odd print out
        • copiertec
          • Jan 2016
          • 2205
          #19
          Correct the MX-3114N is a European model so our hands are tied here in the US. Chances are your SD has failed, start with that then the next logical step would be HDD.
          • gtiporter40
            • May 2023
            • 16
            #20
            Great. That is reassuring. Gives me confidence it is fixable. Thanks for everyones help. If anyone can assist me with the firmware at cost - that would be great. Otherwise I will now see if sharp will sell me that.
            • gtiporter40
              • May 2023
              • 16
              #21
              OK. I bought a new card and it still just blinks green. If I try the hard drive next, is it a case of buying that from sharp or can i use any hard drive and install the firmware on that. Any tips at this point or do I just look to swap the power board out. I do have green lights on the board where the sd card is. There looks to be power. Any help would be appreciated
              • copiertec
                • Jan 2016
                • 2205
                #22
                Any HDD will work, we use WD black as a replacement. You will need the watermark and the e manual firmware and will need to install it once the HDD is installed. I dislike those Toshiba HDD's (high failure rates), I wish they would use a different vendor. For your issues the first two things I recommend is SD card and HDD before swapping boards.
                • gtiporter40
                  • May 2023
                  • 16
                  #23
                  Thanks. I have got the hard drive out and will see if it seems OK first. Am i in the same boat with the watermark and firmware that I had with the sd card I.e. can I only get this from sharp ?
                  • copiertec
                    • Jan 2016
                    • 2205
                    #24
                    Yes, or someone in Europe that is willing to share. I doubt it's the same as US.
                    • gtiporter40
                      • May 2023
                      • 16
                      #25
                      I've attached the drive to the computer and I can see it. I've tried to enclose a picture of one of the drives which has in it the folders
                      "manual"
                      "WM"
                      system.dat.
                      I assume WM is the watermark.
                      The other folder has
                      "fssh" and
                      system.dat in it
                      I can even see my scan folders in there
                      It's not dead therefore and although it may still be corrupt I guess, does it look like I may be better now looking at the power board do you think?
                      • gtiporter40
                        • May 2023
                        • 16
                        #26
                        I switch on and I get the green blinking light on the front of the machine but I do get some lights on the board near the sd card as you can see from the video. The screen is dead though and it doesn't switch on. Based on all advice shall I move to the power board?
                        There aren't any fuses I can check on the board anywhere. I guess that would be too simple. It's a lovely paperweight at the moment!
                        • gtiporter40
                          • May 2023
                          • 16
                          #27
                          OK. The fans don't come on when I switch the machine on. Makes me think that it's not the sd card or the hard drive and it is power. Getting a board seems non existent or not on a cost proportionate basis.
                          I want to fix this else its going to the tip.
                          It seems to me that I need first to see if the required voltage is being generated. I attach a picture of the connectors on the PWB. Anyone know which connector points should be showing the relevant voltage for me to test. The caps look fine but I don't suppose that means anything.
                          Please help if you can.
                          This is the board without connectors attached (not my board)
                          • gtiporter40
                            • May 2023
                            • 16
                            #28
                            I've looked at this guide to the lights on the board
                            Sharp MX-2614N, MX-3114N (SERV.MAN46) Technical Bulletin — View online or Download repair manual | Not Booting Up Blank Screen Procedure
                            From this and looking at my new video below, my power light is normal (furthest light on the left), my sd card shows as fine as there is no light on and this leaves the lights next to the hard drive connector (at the top) and those right at the bottom
                            Both of those are blinking green and I assume if they were fine they would just be on. As such, all signs point to the power board.
                            If anyone feels differently please let me know. Otherwise I may now see if I can see if there are any obvious issues on this. Does anyone know the common failures?
                            Is it the caps for an easy repair? After discharging them of course.
                            I will start looking at this but any nudges in the right direction would help. Thanks
                            • gtiporter40
                              • May 2023
                              • 16
                              #29
                              I am not a technician and I don't know how to amend that. Apologies for that.
