Sharp Fax UX 103 Black copy
  • issahodeh
    • Jun 2007
    • 22
    Hi
    Please help with this fax machine the thermal head is clean and the scanner as well I open it and clean the scanner from inside. but the problem still same black copy as well as when if I send a fax .
    Please advice
  • tmaged
    Owner/Service Manager
    • Oct 2008
    • 1889
    What happens when you print from memory ??
    Hope that helps !
    -Tony
    www.dtios.com
    Become a fan on Facebook
    • Eric1968
      • 2458
      Defective CCD, I think.
      • issahodeh
        • Jun 2007
        • 22
        the reports print out is okay but if I send or copy maybe its need celebration !!!
          • 23009
          I don't know if this fax uses a CCD or CIS, but it's one or the other. =^..^=
          • ZOOTECH
            Senior member of CRS
            • 3375
            After cleaning the mirrors of the CCD unit, you can run the shading wave/CCD adjust diag by feeding a blank sheet of paper through the doc feeder.
            • issahodeh
              • Jun 2007
              • 22
              yes Zoo tech that what I'm asking for can u please tell me how to do it
              • ZOOTECH
                • 3375
                After mirrors are cleaned, press Function, 9, star, 8, #, 7 to enter diagnostics.
                Press # to step forward or star to backup to Shading mode. Put a clean sheet of paper in doc feeder, and press start. It should then read the white reference and store it.
                This is all from memory, and I am a senior member of CRS (can't remember shite) so the steps might be off.
                • issahodeh
                  • Jun 2007
                  • 22
                  Thanks ZOOTECH
                  But it didn't work I think a step is missing or its wrong way
                  If u can find anything that will be great
                  anyway thanks for u & for anyone can help
                  • kentala
                    • 18
                    UX103 black copies
                    Gday,
                    Check/replace the 4 caps after the +- 12 Regs in the power supply.when they go the introduce noise to the rails to the CCD causing black copies.
                    Hope this helps
