Sharp MX4070 blue partially missi
  • Profibastler
    • Nov 2014
    • 102
    [Misc] Sharp MX4070 blue partially missi
    Hello,
    there are fall outs in blue when print via PC.
    C-Devunit, C-drum changed, original toner new.
    Problem the same, see picture.
    Please help, any ideas?
  • copiertec
    • Jan 2016
    • 2211
    Re: Sharp MX4070 blue partially missi
    Have you inspected and cleaned Cyan laser unit?
    • ricohrice
      • Dec 2008
      • 42
      Clean your Laser unit, dirt on the mirrors or the slit glass
      • MHeon71
        • Oct 2008
        • 489
        I agree with Ricohrice and Copiertec. Look at the LSU slit glass. Are you saying that toner is the original toner? I would imagine it has been in the machine for quite a while, along with your other supplies. I would check the cyan DV unit. If the brush on the DV unit is the issue, you will see it. Doubtful, but did you just rebuild the cyan process unit? If so, is everything seated properly, especially the cover over the main charge. I haven't seated it properly before and I would get CQ.
        I would print a 22-6 and see how long the supplies have been in the machine. If your supplies are pushing 2000 days, you should be having CQ issues shortly.
        • Profibastler
          • Nov 2014
          • 102
          Thanks for help.
          What you mean about CQ?
          • MHeon71
            • Oct 2008
            • 489
            copy quality
            • chatkal
              • Aug 2015
              • 47
              Originally posted by Profibastler
              Hello,
              Do you see lines on the mag roller of the С DV unit?
              • Profibastler
                • Nov 2014
                • 102
                Now it works, glass was dirty.
                • Profibastler
                  • Nov 2014
                  • 102
                  Originally posted by kevin32305
                  你的鼓座外蓋沒有安裝好
                  Aha
