Sharp MX3070 yellow shade
  • Profibastler
    • Nov 2014
    • 96
    [Misc] Sharp MX3070 yellow shade
    Hello,
    there are yellow shades when print via PC.
    Y-Devunit, Y-drum changed, original toner new.
    Problem the same, see picture.
    Please help, any ideas?
  • copiertec
    • Jan 2016
    • 2188
    Re: Sharp MX3070 yellow shade
    Have you calibrated the copier to specs?
    • Profibastler
      • Nov 2014
      • 96
      What calibration do you think about?
      Please tell me to do right procedure?
      • OlliK1969
        • Nov 2016
        • 310
        Hi
        have you only changed drum or drum with mk-kit ??
        It seems like drum blade
        • Profibastler
          • Nov 2014
          • 96
          changed mk-kit MX-40GU-SA, blade was my first choice.
          • Mint325
            Hybrid Tech
            • Feb 2016
            • 17
            It's repeating consistently, I wonder if something is wrong with the Yellow Developer unit.
            Ricoh Technician for 6 Years
            Sharp Technician for 3 Years
            Dabbled in Canons, Brothers, HPs, Lexmarks, FPs. etc
            "If I can glue it; I can fix it."
            • Profibastler
              • Nov 2014
              • 96
              What kind of calibration/simulation are necessary to find failure?
              • copiertec
                • Jan 2016
                • 2188
                • ihatefinishers13
                  Senior MFP Technician
                  • Feb 2020
                  • 668
                  What is the measurement between the repeating spots?
                  My first thought was process(drum unit) as we've had issues with those, but I would clean the transfer image density sensors (above right side of transfer) and calibrate the color.
                  • Profibastler
                    • Nov 2014
                    • 96
                    New toner and paper has changed. Now no more problems. Will see next future.
