Sharp MX2614 crum problem
  • Profibastler
    • Nov 2014
    • 102
    [Electrical] Sharp MX2614 crum problem
    Hello Guys,
    MX2614 does not recognize original black toner cartridge.
    Changed cartridge but same problem.
    There`s possible to change crum module or whole logicboard neccessary?
  • leo34staffs
    copierman
    • Aug 2007
    • 503
    Re: Sharp MX2614 crum problem
    Originally posted by Profibastler
    Hello Guys,
    The harness can be ordered separatley: DHAI-4663FCPZ BF GN C CRUM harness (this does all 4 toners)
    Networking skills are advantageous but use of a 3m vacuum cleaner is essential
      • 23010
      Some of the older Sharps had issues with the bracket that holds the modular connector on the inner frame. If the toner cartridge is jammed in there too violently, the bracket will bend away, and the Crum chip connector won't connect. It's something to check for. =^..^=
      • Profibastler
        • Nov 2014
        • 102
        Toner chip was bad (Original!)
