Sharp AR-M237 questions....
  • blacksunshine
    • 25
    what are normal service intervals on one of these, expected lifespan, issues, yadda yadda....
    looking at purchasing a used one...
    TIA
  • tmaged
    Owner/Service Manager
    • Oct 2008
    • 1887
    75K on supplies. Feed tires last about the same. Top trays kind of a bitch to change, so we always default the 2nd tray as primary. Good machines. You can stick a $45 USB print server on it & make it a network printer.
    Hope that helps !
    -Tony
    www.dtios.com
    Become a fan on Facebook
    • mtech
      • Mar 2007
      • 307
      Upper heat roller gets 150K, lower 300K, but kit comes with both. Not a bad machine. Had some developer leak issues early on, but Sharp changed the transfer springs on the right door. (Lengthened them) Seems to have worked. Outside of normal maintenance, just replaced rollers when trays start to jam. Only other thing I can remember is replacing a lot of tray open/close switches. (QSW-B0017QSZZ)
        • 23009
        These machines are a huge improvement over the Panthers & Leopards. As long as you stick to standard 20-28 lb paper stocks you should have very few problems with this model. =^..^=
        • blacksunshine
          • 25
          supplies meaning ....???
          • tmaged
            • Oct 2008
            • 1887
            Drum, Developer & Cleaning Blade.
            Are you an end user or tech ?
            Hope that helps !
            -Tony
            www.dtios.com
            • blacksunshine
              • 25
              not a tech like most of you but a fix it all electronics tech....IT by trade, copier mechanic when I have to be for the ones I have at the time...telephony tech, computer tech, copier tech, printer tech, alarm tech, network admin, systems admin, domain admin, database admin....aka jack of all trades...
