Can not access MX-3071 web page
  • Hansen88
    • 1065
    I read how to fix this not long ago. I tried to search but no luck. What causes the machine web page not to be able to be accessed? Thanks for any help on this.
  • ihatefinishers13
    Senior MFP Technician
    • Feb 2020
    • 689
    Re: Can not access MX-3071 web page
    Could be a number of things.
    Duplicate IP on the network
    HDD is going bad
    mSata is going bad
    MFP/SCN PWB failure
    You're using the wrong IP
    • Prints Charming
      • Aug 2019
      • 189
      Also check the Security Settings for Port Control, specifically HTTP/s haven't been disabled.
      Test connectivity with your own laptop directly connected to the device.
      I've also seen simply changing the IP address 1 number higher/lower fix this issue. Obviously you need to perform extra work after that, but it's quicker than a device initialise/reset.
