MX-M7570 upper web sticking
  • bilyahn
    • Dec 2006
    • 1470
    Good morning
    Have an MX-M7570 that recently started to have the upper web start sticking. Have tried several things so far.
    Replaced the fusing unit, including the web
    Unit worked for about a week and then stuck again
    Adjust sim 43-32 settings for web motion/no change
    When I performed 43-31 web test it originally moved properly then stopped working
    Checked 24VDC to motor/good
    Replaced motor
    Replaced web
    Checked gears on web drive/good
    Test web in sim 43/worked
    Stopped next day web stuck again
    Not sure of my next steps. Thinking something with the harness or PCU board. I notice there is a slightly newer firmware. I will put that in today.
    Any suggestions would be greatly appreciated.
    Thank you.
    Bil
  • Grey Puma
    • Apr 2023
    • 1
    Re: MX-M7570 upper web sticking
    Bill, check the fuser temperature values. It may have been turned back from default at some point due to paper curl, etc. It get very built up due to the unfused toner collecting.
    • Hansen88
      • 1079
      Make sure the pressure springs are pressurized. If toner is not fusing 100% it can load up the web and cause it to stick.
      • bilyahn
        • Dec 2006
        • 1470
        Thank you for the suggestions. I am going back this morning and will check those. I'm pretty sure they are in the correct positions but I have been trying anything I can to figure this out without replacing a board, LOL
        Thank you
        Bil
        • chatkal
          • Aug 2015
          • 47
          Try to set "preheat time" to 1 min. If the fuser stays on for a long time it may dry out cleaning tissue.
            • 23010
            We used to see those sort of problem on very low volume machines.
            At normal print volume the web is consumed quick enough so that it does not stick, but with longer run-up and cool down times, and long sleep timer settings, the web can dry out. I can get so sticky that it sound like peeling packing tape off of the roll. I'm not sure about this model (I was working on Canons at the time), but there may be an adjustment to increase the rate of advance on the web. You'll have to change the web sooner, but it's worth it.
            If you worked on the Kyocera Harrier series (KM-6030, KM8030), we had quite a lot of trouble with keeping the heat roller clean. I got plenty of opportunities to adjust web advance on this series.
            Let me know what you find Bil. =^..^=
            • mommok
              • Jul 2014
              • 48
              we have seen this a lot as well. we have found the web drive control leaver gets worn out ( the machines we have in the field have an average of 5 million clicks on them and get heavy use daily). part number MLEVP1303FCZZ
              • bilyahn
                • Dec 2006
                • 1470
                Hi blackcat
                They do between 3 and 4K images a day so no joy there. I have adjusted the web advance but didn't help. I have ordered a PCU board. Only thing I can figure is there is something with the board not telling the web to advance. One thing I have noticed is the new webs seem awful dry out of the wrapper not like the old web rollers. I have had several of this series have web sticking problems but only after they have been sitting for awhile and it's normally the lower web not the upper.
                • bilyahn
                  • Dec 2006
                  • 1470
                  I looked at the drive gears but did not remove them. But I can advance the web in simulation so I think the gear is good but I will take a CLOSER LOOK.
                  Thank you
                  • bilyahn
                    • Dec 2006
                    • 1470
                    I will give this a try this morning.
                    Thank you
                    • Massimo
                      • Feb 2023
                      • 22
                      E' successo la stessa cosa a me su una mx-m6570 , ho sosituito le stesse cose che tu hai fatto tranne la scheda , sta ora funzionando da mesi perche' ho tolto il gruppo pulizia web superiore , sono tornato dopo mesi e il rullo superiore e' ancora pulito, fammi sapere se cambiando scheda risolvi. Grazie
                      • bilyahn
                        • Dec 2006
                        • 1470
                        Interesting. I thought about doing this but I will let you know. Thanks for the information.
                        Bil
                          • 23010
                          Thank you
                          If you've been able to advance the web in simulation, then you've ruled out everything but the PCB. I think you've covered all the bases. =^..^=
                          • mloudy
                            • Oct 2015
                            • 791
                            Just seeing this happen on one M7570 which was installed 14 months ago in a school. We installed 2 at the same time and only one is doing it. This copier runs 50K per month except for summer time. First showed up at 502K.
                            We are going to install an upper web drive unit from a M654N and see what happens. We have installed different fusers and can advance the web in sims. Runs a few days and stalls again.
                            • Massimo
                              • Feb 2023
                              • 22
                              Hai poi sostituito la scheda ? O hai risolto in altro modo? Fammi sapere mi interessa .Grazie
