Sharp MX 3071 Setup
  • tthomas@ttronics.com
    replied
    Re: Sharp MX 3071 Setup
    Where can I get firmware download, so I can update the machine when installing the finisher? The machine is a few years old and has never been setup, so I figured the firmware needs updating.
  • JP1
    replied
    Temporary Measure Sim 55-01 SW24-7-1 (1 disable) will get paper out without the code L4-11
  • mloudy
    replied
    Nothing else needed. If you need the Installation Guide let me know.
    replied
    Machine was never setup, if I go with the MX FN27N inner finisher, is this all I will need; no other kit needed to get it going?
  • mloudy
    replied
    If this copier had a finisher installed at some point you will also need to get your hands on the foam rings that go on the exit rollers of the shift unit.
    replied
    Thanks for the info, I'll either do that or go with an inner finisher.
  • mloudy
    replied
    This should be everything you will need to recreate a MX-TU16:
    BP-TU10 (this provides the shifter mech, paper full arm, reverse gate and paper fixing arm)
    GCAB-1616FCAZ
    LSOU-0274FCZZ
  • mloudy
    replied
    Will a BP-TU10 work? Wrong color but it might not have any changes from the TU16 other than color.
    I'd try buying a BP-TU10 for the shifter motor assembly and then if you want a color match order the clear tray and bottom tray from a MX-3071 Parts Guide.
    The clear tray on the BP-TU10 is not the same as the clear tray on a MX-TU16. It will not screw on a lower gray tray of the part ordered from the 3071 Parts Guide.
  • JLSam
    replied
    Originally posted by ihatefinishers13
    I really hate Sharp for doing this. Also, you might want to add in what the finished result is supposed to look like... Not everyone enjoys Lego's, but I don't associate with those types of people anyway :P
    Looks good, functional and it works.
    We just keep a set it stock, and we have been using inner finishers. But sometimes we use it when an inner finisher is unavailable, or the end user doesn't need or desire it on the small upsell.
    I didn't add the screws there, because we have a sh*t ton of screws, so, you would need to go through the parts guide and get them yourselves.
    Works great though!
  • ihatefinishers13
    replied
    Originally posted by JLSam
    [ATTACH=CONFIG]60785[/ATTACH]
    Psst, you, yeah you, come here... here you looking for some TU16's...
    Listen my guy... there is a way... but it costs.... 3 times the price ok?
    It's pricey... but I got you... you see, all you got to do is...
    BUY THE PARTS INDIVIDUALLY.
    Makeshift TU16 without screws cheat sheet:
    GCAB-1616FCZZ BD GJ D Delivery tray cabinet
    LSOU-0274FCZZ BA FX D Delivery tray
    LSOU-0278FCZZ AR EQ D Reverse gate tray
    LFIX-0627FCZ1 AD DJ C Paper fixing arm
    MLEVP0960FCAZ AD DJ C Full detect actuator
    PCOVP2711FCZZ AE DS C Shifter motor cover
    MLEVP1340FCZZ AD DJ C Shifter unit slide lever
    QEARP0396FCZZ AD DJ C Shifter unit drive earth plate
    NGERH2492FCZZ AE DJ C Shifter unit reduction gear(24/50T)
    CPLTM9050FC01 AG DX C Shifter unit drive plate
    RMOTS1067FCPZ AY FQ B Motor
    Courage guys. Where there is a will, there is a way.
  • JLSam
    replied
    Originally posted by tthomas@ttronics.com
    I have a customer that bought a Sharp MX 3071 that was never setup. I'm setting it up for him and get a L4-11 code. From what I can tell I have to install a exit cabinet or a finisher.
    I can not locate exit cabinet MX TU16, is there a work around or a new part for this setup?
    replied
    Yea that's what I figured, I did see someone mentioning taking motor assembly out of a BP kit, not sure what they were talking about. I'm a Toshiba dealer, but doing this for a contractor that did some work for us.
  • ihatefinishers13
    replied
    Yeahhhh you're doomed. You'll need to find an MXTU16 exit unit or an MXFN27N finisher and install it. We bought a few finishers from an equipment broker, because we had a few machines without.
  • driving lots of miles
    replied
    My employer has mentioned to me that the exit cabinets are impossible to get. We have had several trade-ins but they all had the inner finishers.
    started a topic Sharp MX 3071 Setup
    Sharp MX 3071 Setup
