BP-50C31 - Slow printing photos
  • MHeon71
    • Oct 2008
    • 490
    Bare with me, I am just getting back into the networking game. Customer states that their photos take 40 to 50 seconds between pages. They set the photos as 2 4"x6" photos per page. They say their last copier was much faster at printing photos. Any suggestions?
    Their old printer was a Sharp, but not sure what model, she said she had least it for 4 years. They are printing wirelessly, but I did hard wire it and did not make a noticeable difference. There PCs are hard wired.
    I have reloaded 1 driver and really did not find anything concrete online or while I was looking at drivers and machine settings.
    Thank you in advance.
  • bilyahn
    • Dec 2006
    • 1470
    Re: BP-50C31 - Slow printing photos
    From other posts I've seen this may be an app problem. When this happens to me first thing I do is install latest and greatest driver (which I see you did) then change the advanced driver setting from vector to raster. Have had some success doing this.
    Good luck
    Bil
    • Sven94
      • Sep 2023
      • 31
      Hey,
      try to set the network speed manually to 1000Mbit/s. We had problems with that. Maybe you can active IPv6 ( helped a lot with AirPrint / MacOS maybe also for Windows )
      SIM 55-3 / SIM 6 / Bit 1 from 0 > 1 and 4 from 0 > 1
      • ihatefinishers13
        Senior MFP Technician
        • Feb 2020
        • 726
        Also make sure it's set to use IP instead of WSD/Airprint, that will slow it down greatly.
        • harps05
          Field Service Engineer
          • Mar 2012
          • 114
          Go to the print driver and try the following:
          Find the correctly installed Sharp Print Driver -> Printer Properties -> Sharing -> Check "Render Print Jobs on Client Computers".
          See how that goes.
          • MHeon71
            • Oct 2008
            • 490
            Thanks for the info, I will give it a shot when I get a chance today or tomorrow. The print drivers are set to IP.
            • MHeon71
              • Oct 2008
              • 490
              Sorry for the delay. I have tried the above suggestions and they did not work. I have since turned it over to my manager and have not heard back.
              • tedtech
                • Dec 2011
                • 50
                If that horrible microsoft photos program is being used, that is the problem. Seen it several times.
                • mojorolla
                  The Wolf
                  • 2639
                  Agree, this is a known issue with Windows Photo Viewer. Open and print the pics in a different software OR put them on a USB and print from USB at the machine.
                  If USB works normally, its a software / driver issue.
