Sharp MX 453 When you do a 2 to 2 or 2 to 1 duplex it get stuck in job status
+ More Options
Posts
  • Lbcoaster
    • 43
    [Misc] Sharp MX 453 When you do a 2 to 2 or 2 to 1 duplex it get stuck in job status
    Sharp MX 453 When you do a 2 to 2 or 2 to 1 duplex it get stuck in job status saying Waiting
    Things we have tried:
    Duplex is not disabled
    Replaced CIS for second side
    Replaced Doc Feeder
    Format HDD
    Any ideas will be greatly appreciated!
    Steve
  • driving lots of miles
    • Jun 2016
    • 403
    Re: Sharp MX 453 When you do a 2 to 2 or 2 to 1 duplex it get stuck in job status
    Have you checked the SD card?
    • Lbcoaster
      • 43
      This gen does not have the SD card like the next generation
      Going to try MFP board from a 283 if I am reading the manual right they appear to be the same may have to change the eprrom
      any help with this will be appreciated
      • WackyJack
        • Feb 2021
        • 82
        I didn't see firmware in your list of things you have tried. Make sure you're at the latest version
        Also, the 453 and 283 do not use the same MFP PWB, at least not according to the parts manual I have. You also have to check if you have the N or U version of the 453, as they use different boards as well
        • ihatefinishers13
          Senior MFP Technician
          • Feb 2020
          • 722
          A machine that old, I'm thinking scan pwb, MFP, or HDD. What does the 5th page of the 22-6 show under HDD Smart Info? If it's anything besides zeros, then back up the customer data and replace it.
