h5-20 on new bp70 m series
  • fireater
    Repair God? not quite
    • Apr 2006
    • 253
    i have a bp70m45 that like to throw h5-20's. every few months. i updated fw. replace fuser did meandering 6-8 "many times". still doing it. i think the fixing sleeve dont turn when its waking up causing the error but i dont see any bulletins or info on this issue. any thoughts?
    I fix copiers ...Well Sorta
  • JLSam
    • Jun 2015
    • 605
    It's a shame no one has responded.
    About to go to service call for this error code, only 2k pages, and 6 months in field. We will see. :|
    Also, there was originally an L4-03 error, then after reboot H5-20.
    We will see.
    • ihatefinishers13
      Senior MFP Technician
      • Feb 2020
      • 693
      We will see.
      I haven't had any issues with this code yet. All I know is, I'd much rather have the 71 series' fuser back because these things are (pun intended) hot garbage.
      • Hart
        • Feb 2024
        • 399
        Only 45 minutes to change the fusing belt, it's fineeeee
        • Smeden
          • Nov 2009
          • 15
          New fuser. it's a worldwide problem. The pressure on the pressroll is to high, due the low fixing temp. Sharp has no solution yet.
          Nothing is impossible for them who should not do it.
          • fireater
            • Apr 2006
            • 253
            we are beginning to think is power issue
