Airpint with authentication
  • boutn
    • Jun 2016
    • 552
    Hello all,
    Is it possible to airprint with iPhone when authentication is enabled?
    The only way i get it working is when i change the "Default User Name for User Authentication:" to "admin" in the airprint settings
    Then i dont get a pop-up, even if the pw is blanck, and then only black&white works.
    If i use any other user, with login/pw or login/usercode, the username pop-up keeps coming up.
  • leo34staffs
    copierman
    • Aug 2007
    • 503
    Re: Airpint with authentication
    Originally posted by boutn
    Hello all,
    An iOS device can print to a MX-XX50/XX60/XX70 device using authentication. However it must be as username and password, not a PIN number . This is an iOS limitation. (From Support)
    Networking skills are advantageous but use of a 3m vacuum cleaner is essential
    • boutn
      • Jun 2016
      • 552
      All very good and well...the airprint manual says the same thing...but have you actually tried this?
      • leo34staffs
        copierman
        • Aug 2007
        • 503
        No, but here is the rest of the answer from support site: Make sure of the following settings to ensure correct operation.Network settings > External Print Services Settings > AirPrint Settings > IPP-SSL Enabled
        User Control > Default Settings > Enable IPP Authentication Except for Printer Driver
        If you want to stop non authorised printing , tick the following option .
        User Control > Default Settings > Disabling of Printing by Invalid User
        NB , The MX3050 requires the MXPK13 Postscript option
        Does this help?.
        • boutn
          • Jun 2016
          • 552
          Does this help?.
          tried all of this, only prints in BW, and only when user 'admin' is filled in
          ps: there are no color restrictions on the users
          • ihatefinishers13
            Senior MFP Technician
            • Feb 2020
            • 731
            An alternative for now, is using the Sharpdesk Mobile app. Eliminates Apple breaking things every update, especially when user authentication is enabled.
            • boutn
              • Jun 2016
              • 552
              But has anyone actually ever tested this instead of searching for work-arounds?
              • danny464
                • May 2019
                • 81
                I have an MX-4070 on the field which airprints with username and password just fine. I remember I tested in the office before doing it and it tested fine here too.
                There is also a setting so that the copier still allows bw or color jobs received without any authentication. This could work depending on what your customer wants.
                • leo34staffs
                  copierman
                  • Aug 2007
                  • 503
                  One thing to try is changing "other user" to having admin credentials
