MX-5141 with Humidity sensor code.
  • Hansen88
    • 1084
    Hello, this machine is giving us F2-58 humidty sensor error. This machine over the years would occasionally throw this code. Now the code will not reset. The machine still works though. We replaced the sensor itself, changed the PCU board and updated the firmware. In the sims the sensor is reading so it seems to be working. Not sure what else to look at on this one.
  • JR2ALTA
    • Feb 2010
    • 2033
    Re: MX-5141 with Humidity sensor code.
    We had to replace the wiring harness to right side door. Not fun. I think we left a lot of the old wiring in there and just worked around it, lol
    • Sven94
      • Sep 2023
      • 31
      We once had a issue with the PCU PWB on a MX-2640N.
      One faulty part was the cassette unit which made that error. ( MX-2651 )
      • ihatefinishers13
        Senior MFP Technician
        • Feb 2020
        • 726
        Did you try cleaning/checking the connector where the right side door/machine meet? I've had bad connectors causing random errors before, and even fuser codes with the fuser connector being a little dirty.
        • driving lots of miles
          • Jun 2016
          • 403
          On this old of a machine I have just swapped doors from another machine in our bonepile.
          • Hansen88
            • 1084
            This is at least part of my plan when I go back.
