MX-C357F Scanning
  • ron67601
    • Jun 2025
    MX-C357F Scanning
    When I scan a document to my network folder I get a PDF and an HTML Microsoft Edge copy. Why is that? I just want the PDF document. What do I have to do to stop getting the HTML one? Firmware is current with 221.204. Thanks in advance Ron
  • ihatefinishers13
    Senior MFP Technician
    • Feb 2020
    • 677
    Re: MX-C357F Scanning
    Are you opening the document in Edge when you are seeing that HTML doc? Also, don't use Edge for PDFs. Use an actual PDF reader, you'll have less problems with anything.
    • ron67601
      When I scan a single page document to a network folder I get 2 documents. I'm attaching the documents I get to this reply.
      • Massimo
        • Feb 2023
        • 19
        Quando crei il percorso di scansione dopo nome utente e password trovi opzioni avanzate togli la spunta a xml
        • ron67601
          When I scan a PDF file format to the computer why do I get a PDF document and a Microsoft Edge HTML document? I just want the PDF one. There has to be a setting somewhere I can change.
          • Hart
            • Feb 2024
            • 373
            It's not an HTML file but an XML file.
            For whatever reason on the Luna/Lexmark models when you scan to SMB an XML file is created, you need to disable it.
            Application -> Scan Center - Network folder -> Setup -> Select your address -> Advanced -> Unselect "XML something something"
            • ron67601
              Ok thanks Hart for the response. Greatly appreciated.
