"Settings have been changed..."
  • mansart
    • 852
    Is there a way to disable the message that appears on the screen of the copier, that indicates changes have been made via web interface...blah blah blah?
    The reason I ask is I have remote access to several school districts. When making changes to the machines, the end users always see this message and they panic.....they employ the old, "We are out of ideas, we have tried nothing", routine.
    It would just be convenient not to have to explain what this message means 5 times a day.
    TIA
  • ron67601
    Re: "Settings have been changed..."
    Reboot machine
    • mloudy
      • Oct 2015
      • 788
      Sounds like you need to do this when you are at home relaxing on your couch just before bedtime and reboot like ron said. Demand double pay.
      • ihatefinishers13
        Senior MFP Technician
        • Feb 2020
        • 709
        Go to Common Settings > Operation Settings > Uncheck Display Status Notification Message
        • mansart
          • 852
          That's it......Thank you.
          • WackyJack
            • Feb 2021
            • 82
            What other messages does this disable?
            • ihatefinishers13
              • Feb 2020
              • 709
              That is a great question in which I do not know the answer to. Probably a question for Sharp, and/or your DSS.
              • mloudy
                • Oct 2015
                • 788
                I found these two things in the USer Manuals.
                Display Status Notification Message: Show a confirmation dialog box when a job is canceled.
                Display Status Notification Message: Set whether to display a notification message when a job is completed.
                • ihatefinishers13
                  • Feb 2020
                  • 709
                  • ihatefinishers13
                    • Feb 2020
                    • 709
                    Another thing this also disables is the Data Clearing message when a Data Security Kit is installed! Haven't figured out what else it does, but this is nearly game-changing for customers! It still makes us reenter simulation when switching between printing modes (ex. 64-1, then 23-2), but otherwise haven't found any other reason why this setting isn't a big deal to disable.
                    • PacMusee
                      • Aug 2016
                      • 55
                      Is there a similar option on the 5070 series? I don't see it following the instructions here...
                      It's not that important for me, but it might help others too.
                      • ridgemill
                        • Sep 2017
                        • 190
                        For models prior to MX-2651 you will need to set SIM55-3, SW 29, BIT 7 to 1, to disable the popup.
                        • PacMusee
                          • Aug 2016
                          • 55
                          Thanks!
