[BP-50C26] More user-friendly scanning after a single scan (address-book entry)
  • Yion
    • Apr 2024
    • 4
    is there a way to make scanning a bit more user-friendly, when doing so from the address-book?
    The current way of scanning is:
    1. A user selects his name in the address book, which has a location to a folder on the network tied to it
    2. The user starts the scan
    3. After finishing the scan, the touchscreen shows, that its selected settings goes back to default
    Now, if the user wants to scan again into his folder, he needs to select his entry in the address-book again and set his custom settings.
    Ideally, it would be nice to let the last selected entry and custom made settings a little while.
    Or as an alternative: Always keep the scanning-address from the last selected address book entry.
    Maybe there is a completely other way around?
    Is this doable somehow?
    Thanks in advance.
  • mloudy
    • Oct 2015
    • 780
    Re: [BP-50C26] More user-friendly scanning after a single scan (address-book entry)
    This worked for the CR4
    Description Sim Soft Switch Data 1 0
    Hold address after scan 55-3 30 3 Hold Do not Hold
    • ihatefinishers13
      Senior MFP Technician
      • Feb 2020
      • 679
      Yes, then you have to also go in to Image Send > Common Settings, and enable the hold address setting. All Sims does is make it visible. Why it isn't an option to check by default, I'm not sure. Probably some useless security idea.
      • harps05
        Field Service Engineer
        • Mar 2012
        • 111
        Just create a shortcut key on the home screen with he pre-defined settings and address already included. THen it's one touch scanning.
        • ihatefinishers13
          • Feb 2020
          • 679
          Yes, but then you have to go back home every time you scan and reselect it. Right idea, but even more steps
            • 8146
            ... is this the same requirement for the BP70C65 Advanced series?
            • ihatefinishers13
              • Feb 2020
              • 679
              This works for a lot of machines thankfully. Here's the original bulletin, there's also a newer one for the Phoenix/Griffin and newer series'
              • Hart
                • Feb 2024
                • 377
                2015 ... And the one publishing the notes on the french portal doesn't understand why I bother him every week asking for shit like this...
                • Yion
                  • Apr 2024
                  • 4
                  I've set the option and did a testscan, but after the scan it goes back to default as it had no effect.
                  Not sure right now if there is another way to approach scanning, for what this option is?
                  Thank you guys.
                  • Hart
                    • Feb 2024
                    • 377
                    Did you change the SW bit ?
                    55-3 SW30 Bit 3 at 1
                    Then in the settings
                    Without the bit and with the bit :
                    • ridgemill
                      • Sep 2017
                      • 183
                      Have you also tried turning on the Hold settings... option?
                      • Yion
                        • Apr 2024
                        • 4
                        [ATTACH=CONFIG]62371[/ATTACH]
                        What do you mean by change SW bit?
                        I don't have a 'Hold adress...' option, only the first one.
                        • danny464
                          • May 2019
                          • 81
                          You need to go into sim mode and change the sim they listed on top. The option will not come out in settings until you do that.
                          Go into sim mode, 55-3, and set SW 30 bit 3 to 1
                          • Yion
                            • Apr 2024
                            • 4
                            It worked! Big thanks to you guys.
                            To enter SIM Mode for the BP-50C26 I had to type: # * C * into the keyboard.
                            I wonder what else is hidden by this method.
