FN27N trouble
  • glimmer1980
    • Aug 2014
    • 105
    FN27N trouble
    Hello,
    We have a FN27N that prints the document but hangs in the middle. I have added a picture below. Every time i print the spring pops out. I allready replaced the springs and rollers, but still the same problem. Does anyone encountered this before?
    Regards Ramon
  • ihatefinishers13
    Senior MFP Technician
    • Feb 2020
    • 732
    Re: FN27N trouble
    The clips that hold it in are worn out. That top cover and everything on it are trash and break, almost every part of it has broken for us.
    • ron67601
      Re: FN27N trouble
      They have updated the rollers and shafts. You will need to replace 0cwflo1960003 and order 0cwfe2e3420// and 0cwfe2d5050//. The bulletin is CCE-2231.pdf . The first item is the black piece that the rollers snap into. I have done many of those. Good luck.
      • glimmer1980
        • Aug 2014
        • 105
        Re: FN27N trouble
        Thanks for your replies. I ordered the "black piece". I will let you know.
        • glimmer1980
          • Aug 2014
          • 105
          Re: FN27N trouble
          Hello,
          I wanted to let you know that it worked with the parts you suggested.
          Thank.
          Regards,
          Ramon
