MXM5071 with grey area at the bottom
  • glimmer1980
    • Aug 2014
    • 105
    Hello,
    At the customer site we have a Sharp M5071 (only black-white) printer. During each print it leaves a grey area at the bottom, see attachment. We allready replaced DV and drum, but the problem still occurs.
    Does anyone maybe have an idea?
    Regards,
    Ramon
  • Sven94
    • Sep 2023
    • 28
    Re: MXM5071 with grey area at the bottom
    How does the fusing unit looks like?
    Maybe you can test it, if you print in A4R to test it. I think the pressure roller is dirty.
    • ron67601
      • Apr 2024
      • 19
      Have you replaced the transfer roller? I've had a few doing that on the edges of prints before.
      • ihatefinishers13
        Senior MFP Technician
        • Feb 2020
        • 695
        Yeahhhhh, the fusing belt looks pretty rough. Coating is worn off and toner is sticking to it. Could also try to run a fusing clean in System Settings, but I don't think that will help you.
        • glimmer1980
          • Aug 2014
          • 105
          Hello,
          What i see is that developer is pulled (we also got the message F2-40). The unit is almost empty. It looks like the developer is burned around the fusing unit. This has been the second time in almost 7 months now. We can replace the developer offcourse but i believe that something else is the problem.
          Does anyone maybe have any ideas.
          • danny464
            • May 2019
            • 81
            Originally posted by glimmer1980
            Hello,
            Did you replace the drum unit or reconstruct? I would replace the drum unit if you have not replaced it already.
            I would also replace the waste toner container as that can cause the issue too.
            • Hart
              • Feb 2024
              • 403
              Replace the whole DV unit.
              We had a problem 2 years ago with humidity in toner that destroyed 3 DV units.
              • ihatefinishers13
                • Feb 2020
                • 695
                Had a similar issue on an MXm365, had to replace the process unit as well as DV unit, the process unit was scratching the drum, and the drum scratched the mag roller. Kept pulling DV every 20k or so.
                • Harry-printer
                  • May 2024
                  • 2
                  If you have replaced the DV-Unit and Drum, ensure that you have cleaned the laser unit glass. Additionally, check the fuser belt, primary belt cleaning blade, and secondary transfer belt for any issues. Also, confirm that the paper being used is original and not a copy. Finally, attempt to print a test page to verify if the problem persists
