Sharp AR-M208 - Machine Locked In Warm Up
  • Tech2002
    • Aug 2008
    • 334
    Got a M208 that I just got through changing the Fuser (brand new) had a issue with one of the delivery sections - good now.
    Was running system and everything working well when Toner Replenishment Light came on, twice, second time changed toner cartridge, this is when it went into Warm Up and will not come out.
    Turned system off then on again. Check my wiring - looks good.
    Any suggestions appreciated.
    Thanks!
  • Tech2002
    • Aug 2008
    • 334
    Fixed issue.
    After about 15 mins in running in Warm Up Model, the machine finally showed an F2:02 Code - the DV Unit is bad. I swapped the bad one with a good one and Voila!!! It works!!!
    This came out of the blue - it just went bad, just like that.
    But, sometimes the simple things in life excite me.
    • OMD-227
      Good to see a dude who is easily pleased.
      • vincent64
        • 382
        I had a ARM 277 do this last week, what I found was the gear between the mag roller and stir augers had worn down, causing the code.
        Swapped the unit, problem went away, mine had 500K + on it.
        • Tech2002
          • Aug 2008
          • 334
          My system had about 350k.
