USB printing ar235
  • Dustin(WOP)
    • 223
    USB printing ar235
    Have a problem changing parts between AR-M208N and an AR-235.
    I had an AR-M208N installed at a customers site. They now want an AR-235. however when I switched the GDI AR-P11 from the M208N to the AR-235 copier gets stuck in system check screen. As far as I can tell these boards should be interchangeable? If not can anyone tell me how I can get my AR235 to print via USB?? I can not find anything in manual about USB printing support. ANY HELP would be great THANKS!!!
  • Wynard
    Used to be a Tech
    • 42
    First off, the AR-235 does not support GDI printing nor does it have a USB port. Its either PCL/PPD via LAN/Parallel or nothing at all, unless there is some difference between the EU and US versions. The fact that the AR-M208 managed to print using GDI and has a USB port suggests a different architecture and therefore hints at an incompatibility.
    However, I fear I cant help you since the EU market has never seen the AR-M208. But are you sure you didnt mess up on the part names? Did you try SIM 22-10 to see whats installed on either machine? Even if there is no printing board in the AR-235 it would still list the required part.
    Since the creation of the internet, the rotation of Earth has been powered by English teachers spinning in their graves.
    • lky1978
      • Mar 2009
      • 483
      ar235b printer board model ar-p11
      arm208 printer board model ar-eb4
      both not same
