Ar m450 network scanner
+ More Options
Posts
  • swagreis
    • Jun 2008
    • 92
    I have a customer with AR-M450 with NETWORK SCANNER option with SHARPDESK WITH LICENSE OF 5 USERS he every now and then change his comuters and the system without remove the old senders from the machine so it is now full of senders and can not acccept new senders and it can not make any scan because of invaild old senders
    is there a way to remove all sender list from the machine
    anyone can advise
    thanks for all....
  • DINGO
    • 661
    re
    Hy
    You can remove it, by the web page of the copier.
    good look
    • tmaged
      Owner/Service Manager
      • Oct 2008
      • 1867
      Dingo is correct. You can get to the web page by typing the IP address in a browser. Then go to destination on the left side. The user name is admin & password is Sharp (cap sens). From there you can remove the scan addresses. The other thing you can do is edit the ones in there to add them to the front page of the address book by checking the Frequent User box.
      Hope that helps !
      -Tony
      www.dtios.com
      Become a fan on Facebook
