Ar 286 scaner is not moving to the end of copy
  • efe311
    • Oct 2008
    • 114
    Ar 286 scaner is not moving to the end of copy NOT everytime , and it make noise & make lines in the paper I change the scanner motor & scanner pwb but the problem steel & I try sim. 1-1 & no problem in the test but it make the problem when i make the normal copy in the screen or from the RADF .
    this problem evry 3 or 4 copy
    PLEASE SOME ONE HELP ME
  • Jamiesdad2
    • May 2009
    • 29
    Bad pulleys
    There are 6 pulleys that the scanner cables wrap around. They contain bearings which go bad. Replace the pulleys and the problem will be fixed. Sharps part number is NPLYZ0167FCZZ.
    Good luck
    • efe311
      • Oct 2008
      • 114
      Did u try this ?
      I will try & i hope
      • Jamiesdad2
        • May 2009
        • 29
        It will work
        I have done it about 20 times. When you get the old pulleys out the bearings will fall out in your hand.
        • lobbelios
          • Oct 2008
          • 5
          Scanner PWB/motor is another idea....wery common problem
          • copyCyber
            • May 2009
            • 6
            Scanner Motor Control Board
            Nine times out of 10 this problem is caused by the scanner motor control board located near the center at the back of the machine. There is an ic on this board that controls the motor signals and it has been know to fail.
            CPWBF1279FC52
            • efe311
              • Oct 2008
              • 114
              I CHANGE THE SCANNER MOTOR CONTROL BOARD & the scanner motor but didnot fix it
              • copyCyber
                • May 2009
                • 6
                Under the mirror 1 carriage there are plastic runners that ride on the rails - they often get filty with grease and dust build up - those scanner motors don't handle much resistance if you clean them and check the rails for dust and clean them with some alcohol it might help and check the bearings on the scanner wire axles both right and left as well as the white nylon bearings for the scanner wires. Sometimes the bearings will breakdown and it takes a closer examination to see. Good Luck.
                • efe311
                  • Oct 2008
                  • 114
                  thank u i will try this tomorrow & i will tell u the result
                    • 23009
                    You said that you changed the scanner PWB and scanner motor, and I believe you. But did you install new parts? Or possibly just re-locate old worn out parts.
                    Like everyone here has said so far, this is a very common problem. So common, in fact, that quite a few of your scrap machines in the copier graveyard probably have exactly the same problem.
                    Have you searched this topic? There are quite a few helpful posts already available to you. =^..^=
                    • efe311
                      • Oct 2008
                      • 114
                      thank u & i will try another sanner motor & scanner pwb from new machin machine
                      • mtech
                        • Mar 2007
                        • 307
                        If I remember correctly there are different scanner motors and/or boards. Something about the motor phase and a setting in simulation. Definately was a bulliten about this Any one else remember this? Without digging deeper that is all I got. I can also remember a time when the main charge actually caused this same problem in an ar-337. When the scan lamp got half way out, the main charge would kick in and for whatever reason the scanner would stop and make a loud humming noise. Replaced the main charge and all was good.
                        • ledoux
                          • May 2009
                          • 75
                          There are two differents sets of motors and boards for this machine. The 2 phase motor has a big brass flywheel on the back of it. The 3 phase motor does not have this flywheel on it. I have ran into 4 times now where I had to put the 2 phase(old style motor) in replace of the 3 phase(new style). Not sure why but I would replace pulleys and put a new 3 phase motor and board on. Problem would still persist. Put a 2 phases motor and board works like a champ. Also make sure you have your sim set right. It's in sim 26 can't remember the subcode. That tells the machine which phase of motor is installed.
                          “Boring damned people. All over the earth. Propagating more boring damned people. What a horror show. The earth swarmed with them.” Buk
                          • efe311
                            • Oct 2008
                            • 114
                            thanks but the motor 3 phase work only on ar287 , ar337 ,ar407 ,ar507 & the sim u can't remember it's sim26 sub 59 & its not work in all machine it's just only on all machine end with num 7
                            • efe311
                              • Oct 2008
                              • 114
                              itry this & its did't work but whin i make any zoom the scanner work without any problem but whin i copy in 100% the problem return any body see this problem tell me why
