MX-5500N Yellow issues
  • graybeard
    • 76
    Got an odd one on an MX-5500N. All individual colors look fine except yellow. We're getting a fade-out toward the front frame side of the machine. The transfer belt is new, the developer...then the developer unit... was replaced, the drum unit is new, and went so far as to try a controller board. The problem occurs on prints and copies. A tech is installing a laser unit today. The calibration has been done the long way, strictly by the book. The firmware is up to date........can you say 'baffled'?
  • ZOOTECH
    Senior member of CRS
    • 3378
    Check the yellow LSU shutter, we have seen them warped a bit causing the problem you described. You may want to check all the shutters at the same time.
    • Dark Helmet
      • May 2009
      • 865
      I have never seen inside a color dragon but ive had something similar on the 2300. The shutters for the color drums did not totally open all the way and parts of the image were missed by a color. On the 2300 there is a big white plastic peice that slides back and forth and opens the shutters when the solinoide activates, the machine was in a dusty enviroment and dirt built up under the plastic and it did not slide smoothly any more and the shutters would some times not open all the way. After removing the shutters and the slider, i cleaned the metal and sprayed it with silicone oil to make it slippery. Never had that problem again on that machine.
      • OMD-227
        Zootech & Lawrence are correct as always.
        I'd check the LSU shutters. Also clean the LSU with the cleaning wand.
        Problem is more than likely the Shutter solenoid, as I've never seen an issue with the C-Dragon actual shutters..... and we have heaps of these machines.
        Check the 24v supply from PCU drops from 24v to approx 0v when operating. If the voltage drops to approx 8.5v, you have a faulty solenoid. If the solenoid is faulty, it hasn't got the power to pull all shutters open. With yellow being on the end, it would open up the least, causing yellow fade out, either through the centre or along an edge (like you are getting).
        • MHeon71
          • 490
          I am not sure if this is your problem, because my yellow was almost non existant from front to back. I had to replace the 2 transport clutches. They are in sec. 59 item 4. I got to this conclusion because the cam on the pri. transfer belt was not in the correct position when all transfer rollers were suppose to be down. Sharp says when the clutches for applying pressure to transfer belt goes, yellow seems to suffer and maybe a little of magenta. I think there is a bulletin on the 3501 but not the MX5500.
          • Dark Helmet
            • May 2009
            • 865
            Wazza to the rescue!!
            FYI locking the shutters open at least on the 2300 is a bad idea. It would be a good test to see if your yellow shows up properly but don't leave it! You get a line front frame to rear frame of each color when the machine runs multiples, you get more colors the longer the paper. I guess the laser does a quick scan when the shutters are supposed to be shut.
            @MHeon7
            I remember seeing that bulletin to, it was a e-clip damaging the shaft and as a result when the clutch would activate to turn the cam to push the transfer rollers down it would hang up or something but it was supposed to be isolated to the 3501/4501 only.
            • graybeard
              • 76
              We stopped a solid yellow so we could see it on the drum......the fade is there. Swapped shutters between yellow and magenta with no change to the image. The solenoid seems to be yanking the shutter open completely (had the side off and could see....good thing it's the yellow). The laser unit itself had no effect. I pulled the drive unit and, please forgive me copier gods, adjusted the receptacle for the post on the developer unit.....yes, I touched red screws. The image improved drastically, but was not perfect. We've emergency ordered a drive unit, and already have a high voltage board on hand just in case. I appreciate the input to this point....I hate hitting a wall with no more ideas.
              • Copy10871087
                • May 2009
                • 7
                Any Luck?
                Any success? We have the exact problem on a 6201 and looking for the answer to this. We also locked the shutters open without success.
                • graybeard
                  • 76
                  Kinda luck......I guess
                  I ended up going back step by step what the last technician had done prior to this issue. Under the rear frame end of the fuser is a block that houses the contacts for the secondary transfer belt. There is only one screw holding that block solid to the frame, and it had been removed. The block was wobbling noticeably. When secured the problem disappeared, but no one....even in my own shop.....believes that was the cause. I just know it's still working.
                  • OMD-227
                    Wow... I'm stunned.
                    Why was that screw even removed in the first place? Never had to touch it myself in years.
                    I'm with you.... cant see how that would fix the image anyway. The image is put on the primary belt, well before transfer onto paper at the secondary belt unit. The problem image cause should be around the yellow drum/dev/shutters/transfer roller etc etc. Will keep an eye out for that one in future anyway.
                    • OMD-227
                      An update on this subject which might help someone in the future..............
                      Earlier today, I was sent to a Venus MX7001N with this exact same fault...... no yellow.
                      Everything else was working fine. Two junior guys had been onsite for quite a while, couldn't figure it out, and asked if I could go help out.
                      With 120 C-Dragon & Venus engine's in the field, and a large number of those pushing 750K - 1Mil or more, I was yet to see an issue with just the yellow missing, and everything else OK, without error code or unusual noise.
                      Of course I had seen and do regularly work on MX3500/4500N's with no yellow due to the transfer clutch or clutch shaft/main drive unit failure's, but was yet to see this on a C-Dragon or Venus. There is definitely no bulletin on this subject for this engine, only the Pastel1 & C-Jupiter1's.
                      A quick check of what they had done was OK. I performed a solid yellow page sim 64-01 and the image on the drum was great. All shutters, drums, devs, firmware, bias voltages etc etc all OK. With new Primary & secondary transfer belt units fitted only 85K ago, these were immediately dismissed as cause of the fault by the other guys.
                      I even remembered what Graybeard had said earlier about the secondary transfer charger housing block that was loose, but this one was OK (never had to remove that part anyway).
                      I was certain that this was a transfer issue, due to the fact the yellow drum had a nice solid page on it in sim testing.
                      By running sim 6-03 transfer load test, with the front cover lowered and front door switch tricked, you could just see that the yellow transfer roller was lowering onto the yellow drum OK, but the yellow follower/support roller (also within the transfer unit - beside the yellow transfer roller) was not lowering down all the way, therefore not fully pushing the belt onto the yellow drum surface.
                      The primary belt unit was removed and the cam assembly for driving the black & color transfer rollers within the belt unit downwards seemed to be alot tighter than normal, when driving it by hand. This seemed to explain why the yellow follower/support roller which lowers down last on a color page, was not fully dropping onto the yellow drum due to excess load.
                      A C-Dragon MX6200N on the same floor was temporarily 'raped & pilaged' of its primary transfer belt unit and the yellow immediately worked in the problem MX7001N.
                      A new primary transfer belt unit was fitted to the Venus and problem solved!
                      I remembered this post and wanted to update everyone with this issue to check the primary transfer belt (even if it looks good and appears to work fine!)
                      See some samples of before/after sim 64-01 halftone prints (sorry abou the detail... just 300dpi USB scans).
                      • Sharp Fixer
                        MX700U1 MX701U1- be sure to use the right transfer belt unit
                        the mx5500 family uses the MX700U1 belt and the mx5501 family of machine uses the MX701U1
                        the 2 units are similar but not identical
                        Had the same problem (loss of Yellow) appear after a day or 2 when i accidentally installed the wrong unit
                        a quick check of the service history confirmed the wrong unit. Installing the correct unit solved the problem.
                        • OMD-227
                          I hear ya mate, but this was the right belt.
                          But......We have been using both belts in both machines perfectly fine for years now..... no problems. The parts breakdown list is basically the same. I know its wrong, but we dont have any problems using either belt unit. This was an actual hardware fault, not an incorrect part. As you can read in my above post, I put a transfer belt from a C-Dragon into a Venus, and it immediately fixed the no-yellow issue, as the yellow transfer roller & follower roller were being lowered correctly.
                          I would say that our C-Dragon and Venus machines have done several million pages now using the 'incorrect' transfer belt unit. Never had a problem. Its just like the Pastel & C-Jupiter belt units. They work perfectly fine when swapped around. You just need to put the heat-sink on the C-Jupiter belt unit cleaning assy if you are using a Pastel belt.
                          Its a beautiful thing when parts can be inter-changed and work perfectly fine. If you have a look at the parts list side-by-side, you usually only see one or two items that are different, and then its only by one number or FCZZ vs FCZ1 etc etc.
                          Just use what is available in your stock at the time.
                          PS... there is no such machine as the MX5501, but I know what you mean.
